I am not sure without trying it myself. I personally would extract the exif data from the photos in order to grab all of the attributes that I would (like x,y, and z), then put those back into the attributes of the point feature.
Thanks for the tip.
However that tool requires that you have an attribute field for the Z component.
I do not have this… kinda the point of this whole thread!
When I try to generate Z coordinates using update coordinates or some other tool all I get are zeros or nulls.
So either I try this tool before generating the false Z values; and the tool doesn’t run… or I try it after generating the Z field full of zeros and the 3D features are tied to the ground…
Or was there some other way to get the necessary Z values so that this tool can work?
Nigel Baker
Maybe first try converting these features to 3D:
Feature To 3D By Attribute—Help | ArcGIS Desktop
Then try getting Z values.
I have the same type of problem and simply cannot believe that this is still an issue.
I have gps data which i have extracted from photo metadata and converted to .kmz using geosetter.
I import this data using the kmz to layer tool and then save the points to a shapefile.
if i select a point the coordinates of the point are shown in the pop-up window in full with x, y and z (altitude).
then i tried both the 'Add XY Coordinates' tool which returned a 0 for all the z values and the 'add geometry attributes' tool which returned a 'null' for all the z values. the XY coordinates were written correctly.
what is the deal? it is 2019, we live in a 3D world. why is this so difficult?
please!
I'm late to the party but this tool in Pro works great!
Add Geometry Attributes—Data Management toolbox | ArcGIS Desktop
very usefull! any suggestion if i want to create a line with a start and end point which is not drawn at the terrain but as a chord, to get after that the z values?
You could use the python syntax and write:
!Shape!.firstPoint.Z
More examples here: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
well i have the same problem i tried but i am getting only x,y coordinates, i am using 10.2.2.
