I'm currently testing Experience Builder and trying to develop my own widget. I needed to install Experience Builder offline to use it and now I can't use the esri library.
Do you have any solution to help me ?
Thank you
Try adding the jimu-arcgis dependency in your manifest:
WidgetManifest
There may also be an issue loading your typescript definitions (VS Code maxes out scanned files). A previous solution was to modify the tsconfig.json file:
Previous Solution
Good luck!
Thanks !!
I already added the dependency before. So I added all this files to the exclude part and it worked for me !
Thanks you !
The 2nd solution from DougLogsdon2 worked for me. you need to update the tsconfig.json file
"exclude": [ "node_modules", "arcgis-js-api", "dist", "__mocks__", "jest-systemjs-transformer.js", "jest.config.js", "jimu-for-test", "webpack.config.js", "webpack" ]
