I am using Survey123 3.13.246 App. when i try to edit existing surveys in inbox folder, I could not see any attachments for view/edit or delete.
Viewing images in the Survey123 field app inbox should be possible as it is a new feature that was added back in september 2021:
https://www.esri.com/arcgis-blog/products/survey123/announcements/whats-new-in-arcgis-survey123-september-2021/
Are your attachments in repeat questions? If so, you need to ensure you have query allowUpdates=true in the bind::esri:parameters column on the begin repeat question.
See this post: https://community.esri.com/t5/arcgis-survey123-questions/view-pictures-of-submitted-surveys-in-inbox/td-p/1015413
I knew, it was added in September.but i unable see the uploaded attachments in survey123 app .
