Tangential to a tool to check continuity between fabrics, being able to import fabric types from another fabric to a new one would cut down on set-up time.
If Copy Parcels had an option for "schema only", that would be really nice.
A decent workaround: if you run Copy Parcels with a parcel selected, it will still create a whole new parcel fabric with the entire schema, but will only copy the selected feature in, along with any associated records, lines, and points.
At left, a test parcel fabric. Upper right: copied fabric with selection. Lower right: copied fabric without selection.
So just select a single parcel, run Copy Parcels, then in the new parcel fabric, delete that single feature.
@anna_garrett
Good idea by @jcarlson .
Another option, assuming you look to copy the entire schema from one environment to another, is to export and import a 'Schema only' workspace XML that is documented here.
Step 1:
Step 2: Import it
Would this work?
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
