It would be great if we were able to filter based on an attribute within the field maps app (i.e. populate the map with inspections still needed to be done or certain trees).
Already been asked for a lot the last few years. Here are some of them - please upvote.
https://community.esri.com/t5/arcgis-field-maps-ideas/add-a-filter-widget-to-arcgis-field-maps/idi-p/1032418
https://community.esri.com/t5/arcgis-field-maps-ideas/filter-functionality-in-arcgis-field-maps/idi-p/1070749
https://community.esri.com/t5/arcgis-collector-questions/offline-filtering-in-collector/m-p/111332
https://community.esri.com/t5/arcgis-collector-questions/offline-filtering-in-collector/m-p/111337
https://community.esri.com/t5/arcgis-collector-ideas/configure-filters-or-searches-in-collector/idi-p/924507
https://community.esri.com/t5/arcgis-collector-questions/filters-on-collector-offline/m-p/79954
https://community.esri.com/t5/arcgis-collector-questions/filtering-data-in-collector-classic/m-p/725330
thanks
Just saw this changed to implemented (nice!) - when will the functionality be available in the (iPhone) Field Maps app?
Hi @LindsayWithers1 - this can be enabled today when using ArcGIS Online and available from ArcGIS Enterprise 11.1 and later. You configure this functionality for users in the field using Field Maps Designer. The help is available here on how to set this up: https://doc.arcgis.com/en/field-maps/android/help/configure-the-map.htm#ESRI_SECTION2_D4A1D89377A3411C8CA25C49F1C28187
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
