Is there a way to be able to search in the survey123 map based on the linked content?
Hello @ZGutknecht,
If possible would I be able to obtain a little bit more information on the full use case? Are you looking to search based on a layer within the web map that is linked to your survey?
Thank you,
Zach
That is correct. In Survey I linked a parcel map and would like to be able to search based on the parcel ID.
Thank you for confirming! Unfortunately Survey123 only supports using locators to search in the map. I've created an issue internally to enhance the map capabilities to use the feature/table search configured in a linked web map.
Please feel free to log an idea in the ArcGIS Ideas page and/or log a case with Esri Technical Support and they will be able to log an official Enhancement to support the workflow.
