I'm wanting to know if MDM AppConfig properties are available for configuration in Field Maps. I've seen some decent information for all of the other apps:
Survey123: https://community.esri.com/t5/arcgis-survey123-blog/configure-survey123-properties-in-your-mdm-with-appconfig/ba-p/894864
Field Apps in general: https://www.esri.com/content/dam/esrisites/en-us/events/conferences/2020/developer-summit/mobile-device-management-technology-and-arcgis-field-apps.pdf
But nothing on Field Maps. Is this possible?
Hi @Mandalorian,
> ... if MDM AppConfig properties are available for configuration in Field Maps
Yes, ArcGIS Field Maps does support MDM configuration properties. Please review this help topic,ArcGIS Field Maps - Mobile Device ManagementFYI, a new technical paper on the topic of MDMs and the ArcGIS Field Apps will be published very soon.Hope this helps,
Hi @Mandalorian
Additional to the Help topic Derek mentions above, you may also be interested in watching Dev Summit presentation: ArcGIS Field Apps: Working with Mobile Device Management Systems.
Hi @Mandalorian, The technical paper is now available, New Technical Paper: ArcGIS Mobile Apps & Mobile Device Management (MDM) Support Hope this helps,
Hi @DerekLaw
I'm reading through the steps and parameters on the document linked here https://doc.arcgis.com/en/field-maps/android/help/deploy-your-map.htm#ESRI_SECTION1_F7DE2402BA8743E5BFC4A1241072960E on this thread.
My Question is I have an arcgis Online map that I want to link to. I'm able to get the mapped link, but it still gives me the option to either click online or enterprise to login. Can make it go directly to the Online link bypassing the need to click Sign in with ArcGIS Online? I see there is an option to define your portal address to do this. I just need to do this with ArcGIS Online.
Hi @LindseyStone, > I'm able to get the mapped link, but it still gives me the option to either click online or enterprise to login. Can make it go directly to the Online link bypassing the need to click Sign in with ArcGIS Online?
I don't think this is currently possible in ArcGIS Field Maps (to bypass the sign in dialog), nor with an MDM deployment/configuration - sorry. Please submit an enhancement request on the ArcGIS Ideas site for Field Maps.Hope this helps,
Has ESRI ever released more than the current key values for Field Maps app configs? ESRI support keeps sending me the white paper to reference for the key values but I need additional key values. For example I want to set the Collection Settings in Field Maps.
Hi @DanPearce,
FYI, the latest parameters supported with MDMs by ArcGIS Field Maps are listed in this help topic,https://doc.arcgis.com/en/field-maps/ios/help/deploy-your-map.htm#ESRI_SECTION1_CC53DED5869D43EA8357CDFE7CAE8959> ESRI support keeps sending me the white paper to reference for the key values but I need additional key values.
Apologies, we haven't had a chance to update the MDM whitepaper yet; with the info in the help topic above.Hope this helps,
@DanPearce collection settings can be configured via the Field Maps web app on a per-map basis as described here. In many cases collection settings differ between maps, so this allows flexibility while still pre-defining values so each mobile user doesn't have to configure when signing in.
Hello @HeatherMcCracken , @DerekLaw , @DougMorgenthaler , @ChrisDunn1 , @Anonymous User
We're attempting to deploy FieldMaps via InTune and have the following set up:
If a user is in the Production group and installs Fieldmaps they are immediately directed to our production portal. Excellent! 😎
However, if they are then moved to the Stage group the Stage URL is added to the list of potential portals FieldMaps can access but the Production URL is not removed.
Is this expected behaviour?
Hi @ahargreaves_FW (just reread your post, and realized i misread. So updated answer below, i deleted my first response)It is expected that the Production URL is still included in the list portals that you see when you manually tap to sign into Field Maps. This list is actually a "recent portals" list, not a "potential portals Field Maps can access" list - so it will continue to show the Production portal URL as it is a portal that has been signed into successfully.Noting, however, that when the portalURL value is set, when the app is launched the user should be brought right to the sign-in screen for the portal so they shouldn’t see that list when they launch fresh. That list would only be shown if they sign out of the Stage portal, and then manually sign in again without killing/relaunching. As if you kill/relaunch FMs it would take them automatically to the portal specified in the portalURL.If you did want to clear this list - you could uninstall/reinstall to clear this out.Hope this clarifies. Let me know if further questions.Thanks,Heather
@HeatherMcCracken thanks for the clarification....
