When will I be able to develop a custom widget for the ArcGIS Portal OPS Dashboard?
Hi Brian,
ArcGIS Dashboards currently does not offer any extensibility options and there are no immediate plans to enable a developer framework for it.
What functionality do you think is missing that you want to develop a custom element for it? Your requirement might make for an enhancement request. Please be as specific as possible.
Hope this helps,
> The requirement is to be able to build widgets, preferably with the same API we use to build widgets in the WebApp Builder Developers Version.
As I mentioned, there is no developer options for ArcGIS Dashboards at this time. You can vote for this idea: Operations Dashboard Developer Edition
> ... it would help if the OPS Dashboard widgets provided a way to execute a custom action that can call Avenue.
Are you referring to Avenue, the scripting language for ArcView 3.x? Both the product and scripting language are retired and unsupported by Esri. What does the Avenue script do? That would likely be the enhancement you could submit for ArcGIS Dashboards on the Ideas site.
Apologies for the late reply.
> I meant Arcade, or better yet Python. As far as what it could do, as a developer, I'd want to be able to pass parameters derived from the dashboard data sources to whatever, a web service for example, get a response, parse out what I need and then display it on the dashboard somewhere, like in an expression belonging to the widget the script is called from.
FYI, the new ArcGIS Dashboards Beta has enhanced support for Arcade expressions. And when it goes final (coming soon in the next ArcGIS Online update) it will have new functionality where you can use Arcade to define data expressions - this might meet your needs. I suggest you wait to check this out.Hope this helps,
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
