ESRI support tells me that Insights is not compatible with Enterprise 10.6.1? I'm also kind of confused why ESRI would not make sure that insights is compatible with 10.6.1. Does anyone know when a compatible release is scheduled for?
FYI, Insights for ArcGIS v3.0 was just released today.
EDIT: Checkout this blog for details about the release, What’s New with Insights 3.0 (September 2018)
Hope this helps,
Hi Daniel,
Please see this GeoNet thread,
https://community.esri.com/thread/218287-how-long-until-i-can-use-insights-with-enterprise-1061
The next release of Insights (3.0) will be supported on Enterprise 10.6.1.
When is the expected date for the release of Insights 3.0 I upgraded to 10.6.1 and assumed that all supporting components would work. ESRI should have really documented that better here. I did not find out until I was done with my upgrade. Now we are stuck because Insights does not work.
I had to add this in order to get InSights to connect to my SQL Server
Microsoft JDBC Driver 6.4 for SQL Server from
https://www.microsoft.com/en-us/download/confirmation.aspx?id=56615
Extract and drop this file: mssql-jdbc-6.4.0.jre8.jar into:
*:\Program Files\ArcGIS\Server\framework\runtime\tomcat\lib
Is anyone able to download insights 3.0? It's not; showing up on my.esri page. My Customer Service Rep has been looking at it since this morning. I just need the link to the download?
https://my.esri.com/#/downloads/Insights for ArcGIS/3.0
There's nothing under 'Download Components'
This is what it looks like for me.
