can you connect power BI to Portal for ArcGIS hosted on premise
ArcGIS Maps for Power BI now supports connecting to ArcGIS Enterprise.
ArcGIS Maps for Microsoft Power BI – March 2020.1 Release
Hey Tyson - at this time no, this map visual does not support ArcGIS Enterprise / connections to Portal for ArcGIS. It's a hot topic of discussion here at Esri, though, and we're working through some technical challenges to see if it's possible to provide ArcGIS Enterprise support.
One of the technical challenges is supporting secure connections from Power BI back to ArcGIS Enterprise. The underlying technology (chromium) that Power BI provides for visuals doesn't support all authentication types. It would be great if you (and anyone else requesting ArcGIS Enterprise support) could email me information about how you authenticate to ArcGIS Enterprise. This would help us understand if what we can build will actually work for those of you who want this feature. You can reach me at s b a l l @ e s r i . c o m - thanks!
Scott,
Thank you for the update.
Fyi: We are authenticating into our on-premise portals via Enterprise logins via SAML and using Azure AD as the identity provider. “ Which is working very well”.
Hey Tyson Taylor - another follow-up question regarding your request: at your company do you use the out-of-the-box version of Power BI that is based in the cloud ("Power BI service"), or do you use the on-prem version ("Power BI Report Server")?
Hi, has there been any progression with this feature?
For our portal we have manual accounts created, no auto logins.
And we use both versions of Power BI depending on the business use case, the average user would just use the cloud version while advanced users utilise the on prem version.
We I believe are using the on-prem version power BI report server.
We are also interested in this feature. We're using the Power BI service and ArcGIS Enterprise on Azure VMs, authenticating with Azure AD.
Excellent thank you.
Hi all,
Jon Emch, Dynasty Machado
I am trying to access to ArcGIS Map for power bi using ArcGIS Enterprise Portal account but it returned a below message:
Do I have to have add-on license for the ArcGIS Enterprise 10.8? if yes, how?
Kindly help me out here.
Thanks
Good morning Hussam,
Correct, you will need to purchase an ArcGIS Maps for PowerBI Add on license to work with ArcGIS Enterprise 10.8, more info on purchasing can be found here: ArcGIS Maps for Power BI Pricing | Add License for Access
Thanks Jon!
Hi, My PowerBI Desktop is successfully connected in Portal for ArcGIS 10.7.1 using ArcGIS Account. But I Can't sign in upgraded Portal for ArcGIS 10.8.1. Please help answer this question
10.8.1 utilizes the ArcGIS for PowerBI Add on license. Although this license was deprecated, 10.8.1 still requires it. You should be able to go onto myEsri and regenerate your ArcGIS Portal license with an allocation for ArcGIS for PowerBI Add on licenses. If you dont see those licenses there, contact your CSR.
If you do have the add on license, could you make sure that the ArcGIS Enterprise 10.8.1 deployment is accessible to the internet.
Hi Jon,
I'm experiencing the same problem as listed above with 10.8.1. Can you expand on what you mean by deprecated but still required?
Thanks a lot for your help.
Bryce
