Power BI の Esri Map ビジュアルが設定を保存しません。1つの国に基づく境界マップのためにすべてを設定しましたが、問題ありません。別のタブに移動して戻ると、すべての設定が失われています。これは以前は問題になっておらず、Power BI の5月版以降に問題が発生しているようです。ここで報告されたバグが再び発生しているようです。 https:\/\/community.powerbi.com\/t5\/Issues\/ESRI-ArcGIS-maps-arent-saving-changes\/idc-p\/1099172#M57047<\/A> <\/P><\/BODY><\/HTML>
The June 202 release of PowerBI Desktop should resolve the persistence issues.
Hello all,
I am a representative of Esri Technical Support. We are currently tracking this behavior that occurs in PowerBI Online. Would you please reply to this thread with the region location of your PowerBI Tenant? You may access this information by going to PowerBI Online and clicking the question mark next to your profile picture.
At this point in time, we know that this behavior is occurring on certain PowerBI Online datacenter regions. If you have maintenance, I would advise you to open a case with us.
I am finding this issue is occurring in Power BI Desktop. I have not tested editing online but the maps that I already have set up online are working. I am in Australia if this helps.
When online here is my server. Australia Southeast (Victoria)
I am not sure if this is connected but it has only started to be a problem more recently so may well be. Choropleth maps using the location boundaries previously worked well. Now the polygons are not rendering correctly for all of the areas and you end up with this.
Hey David,
If this is occurring in PowerBI Desktop, my first recommendation would be to reinstall PowerBI Desktop with the latest and greatest. You can find this installer here:
https://powerbi.microsoft.com/en-us/downloads/
Hi Jon Emch, I think it is the latest and not so great May version of Desktop that is causing all the issues. Certainly as reported here if you were to roll back to the April Desktop the issue with losing setting goes. The issue with Polygon shapes was there previously but seems to be a lot worse with the May version.
https://community.powerbi.com/t5/Issues/ESRI-ArcGIS-maps-arent-saving-changes/idc-p/1108440#M57141
Same same and only in desktop !
Could you post the PBIX you are working with?
Hello Ori
Hello Jon Emch,
Same problem in PowerBI Online, April 2020 desktop version works fine.
The problem occurs when published on PowerBI Online, the visual resets to default settings.
All colors and boundaries configurations resets to points and the visual doesn't make sense.
This is the region of PBI Tenant (North Central US (Illinois))
Any updates or expected resolution time?
Thanks for your support on this.
Jon Emch We are experiencing the same issue with our Power BI reports. Server is 'North Central US (Illinois). Maps are not presenting the base map settings, color schemes, and boundary settings. Refreshing the page allows the map settings to present appropriately, but not on initial page load up, and once the user's cache clears it reverts to default.
I can't due to the nature of the data, but it seems like consistent issue?
Any update on a fix for this save settings issue? I use the Power BI Desktop app. It automatically takes all monthly updates from Microsoft. Based on reading this and the PBI community logs, sounds like an issue from the May release of updates?
Hello Mark,
A defect has been written to address the PowerBI Desktop issue: BUG-000131196. If you would like your account added to this defect, please log a support ticket. Once I see a change in the behavior, I will update you all here.
How can I do it if I am not in the USA? AUS
Hello Jon Emch,
I have the same problem here in my Power BI desktop version. It doesn't save the changes I have made in the ArcGismap. I already updated my Power BI desktop to the recent release in May.
Also, a few weeks ago I noticed that when I published my Power BI desktop report to PBI online, the heatmap I set was gone. Only the default theme of the ArcGismap appeared. Based on the reactions on this page the two problems are probably related?
My server is located in the Netherlands, Western Europe.
We have also noted this behavior in the Netherlands datacenter, and Microsoft is aware of this. I will keep you posted on updates as they come.
This issue has also been solved with the June Desktop. Good to see it largely all seems to be working again.
Thanks for your update, I think everything is working fine now
Hi, one of our clients is experiencing the same issue. Is there anything happening on ESRI side? I am now gathering more info from client so I might post some update about it later (PBI version, if it has worked earlier,..)Thank you in advance for any input.
This post is over a year old and based on the older tech that has been replaced. If you are experiencing this, please start a new thread and supply screenshots or videos where possible so we can best identify the issue.
The best way to report issues to ensure they get fixed, is to reach out to Esri Tech Support. As a customer current on maintenance, our support team will spend time learning the issue and coordinate with our development staff to identify a resolution.
