Hi Aaron,
Thanks for the update on your post.
Hi Rick, I'm trying with your suggestion that using network dataset. Is it possible to create multiple bus route in one solve? How do I do it?
Thanks in advance.
Thao
Yes Thao, when you create your stops, you need to set a property of the stop with a specific Route name. Then when the solver runs, it knows to treat those stops with individual routes.
Thank you Rick. I got it generate like the way I want. However, I receive error when generate schematic diagram. It's saying 'Error during schematic diagram generation. Unable to create schematic feature class. The name of the Field is invalid: valid names may contain letters, numbers or underscores.' Please see the attached files for detail the problem. Would this be solve easily?
The error is on the internal schematic tables it looks like. If you create a brand new fgdb with a schematic dataset and 1 diagram template configured for the network dataset builder and then try this again, is it OK? Make sure the builder is network dataset. Here is a link to the tutorial showing this.
Hi Rick,
I've just tried again. Created a new FGDB, new schematic data set, new template, with Network Dataset Builder. But had same error. Not sure because of the version 10.2. As I was successful generated similar schematic diagram with version10.0 (see this threat How can I make schematic diagram has the same symbol with Routes from Network Dataset )
