Hello, I am using the ‘Make Route Layer’ tool. Usually, I manually enter the optional ‘Start Time’. However, I have a field in a table where different start times are stored. Is there a way of automatically feeding these different start times to the ‘Make Route Layer’ tool? This will enable me iterate through the range of start times. Thanks in anticipation.
You have to change the time of day for the route layer and resolve. You can do this using python. Take a look at page 20 of this Esri Dev Summit proceedings to do exactly this:
http://proceedings.esri.com/library/userconf/devsummit17/papers/dev_int_94.pdf
Jay Sandhu
