I was looking for a way to get the routed road segment IDs from the resulting path in arcpy Python (notebook). I simply want to get the mapped road segments when we submit a set of stops. Can someone help me with that?
Melinda Morang Thank you for the response. The example there seems bit complex for me as I'm a newbie for arcgis. Can you pls share an example in ArcGis Pro for a dummy path?. That would be really helpful. Thank you agian
I'm not sure if this works in a Python notebook, but with arcpy in ArcMap or ArcGIS Pro, you can use the Copy Traversed Source Features tool to get what you want.
