Hi All,
Assume there are 12 crossroads for a user want to visit in a city. Could you help to find a best way without U-Turns?
Please see the attach for details.
Bests,
Leo
I once did something similar for my mother in law when she wanted to visit all the assisted living facilities in my town.
however, I simply put the addresses into Google Maps and kept sliding stops up and down until I got the shortest route.
Then you would need to include roads in with your diagram and question.
Hi Robert,
It could be work for regular network, however the nearest stop might not be the closet stop in a network.
And it not avoid U-Turn.
1 2 3 4 6 7 5 9 11 8 10 12 11
There is an easy if not a little complex way. you can generate a near analysis on each point to find the point that is closest to it. start off by drawing lines between a point and its closest neighbor
9 would go to 11
12 to 11
10 to 12 and in this case 8 might go to 9
3 and 4 would partner up but instead go to 6
Here is a result with U-Turns in ArcMap. It's not the solution for the question.
