I did not think it would be a big deal either, but I just checked the properties of RMDs in ArcCatalog in 10.5.1 and after that I was unable to access the RMD in ArcCatalog and the 10.3.1 image service connected to the RMD no longer works.
We have noticed the similar issue:
Steps to reproduce:
- in ArcCatalog 10.3.1, create file geodatabase, create mosaic dataset, add raster jp2 to the mosaic dataset.
- in ArcMap 10.3.1, add data i.e. the mosaic dataset, make sure it works, remove data.
- in ArcMap 10.5.1, add data i.e. the mosaic dataset, open Footprint layer attribute table, start editing, edit field MinPS to value 1, save edits, stop editing, close the app.
- in ArcMap 10.3.1, try to add data i.e. the mosaic dataset, make sure an error message appears "Error opening mosaic dataset"
Rebecca:
I'm still not sure what the exact mechanism is that upgraded some of my RMDs to 10.5.1 (still trying to make this determination on copies as I corrupted some production data for 10.3.1 in my original investigation). I'm thinking it might be when you are in ArcCatalog with the file geodatabase where the RMD in focus, go to the Contents pane and right click on an RMD to access the Properties. I believe just viewing the Properties of the RMD in this manner with ArcCatalog 10.5 caused the RMD to be upgraded (There are 11 tabs under Properties so it might even be that you have to access a specific tab for the RMD to upgraded - I say this because in the past with lyr files they were upgraded to a later version if you went into the Description tab where the metadata was auto-updated - No problem using the Content or Preview tabs though).
Do you have your RMDs all in 1 file gdb?
Do you dedicate a file gdb per RMD?
I'm just trying to see why my environment is working much differently (worse) than your environment.
mvolz47 My RMD's (in a file GDB format) were created using 10.2.2 and the services are the same. I am able to view bot the Mosaic Dataset and the services using ArcCatalog from 10.2.2, 10.3.1,10.5.0, and 10.5.1 (never installed 10.4.x).
This is a good exercise for me to make sure our RMDs are compatible. I only looked using ArcCatalog (not ArcMap) and I have not tried to make a ArcGIS Server 10.5.1 image server, since that isn't installed yet.
When on the 10.5.1 machine and looking at the .gdb properties, the "Upgrade Status" says "This 10 Geodatabase matches the ArcGIS Release your are currently using.", so my guess is the format is the same between them.
Just to make sure it didn't auto-update to 10.5.1, I opened up my 10.2.2 ArcCatalog and all is still fine. The "upgrade status" for that version is also ok...but does not have the "10" in the message.
Is it possible that your mosaic hasn't been upgraded to the 10.2.x version yet?
Try viewing the RMD that you looked at in 10.5.1 on a 10.3.1 or whatever lower version machine you have in production and see if it still works.
I looked using 10.5.0 and it worked. Working on upgrading to 10.5.1 on this test machine and will get back to you.
edit: may be a couple hours...taking a while for the upgrade and I'm heading to a meeting...so after that.
