I'm having an issue with some hosted layers not being able to load in Collector in both the app and Windows edition. On the app, I get a Code: 3018 runtime error.
On the Windows app, I get a Field Already Exists: created_user error. Why would it be trying to create this field again?
Screenshots attached.
Thanks
Chris
Hi Chris -- we've seen some issues with editor tracking fields that are affected by how the layer is created. How was your layer created? In Pro and published to ArcGIS Online, or within ArcGIS Online? Could you share the list of fields your layer has, or if possible your layer with Collector4ArcGIS (the easiest way is to create a group, share the layer with the group, and invite Collector4ArcGIS to the group).
Another thing you can try is enabling logging in the developer settings on the iPad (triple-tap on your user name in the profile, and you'll see a "developer settings" option appear). You can enable logging in the developer settings, then reload the map, and see what information you learn.
(Hope all is well! )
Hi Kylie,
The layer was created in the Portal (we're using Enterprise 10.7.1) using the template of another feature layer. I'm sending you the login info.
Hi Chris or Kylie DoniaDid you find a resolution to this?
I've got the same environment Portal 10.7.1 and iOS Collector.Only thing it may be is that my feature class has a relationship class.
I've created from both ArcMap and ArcGIS Pro.When I disable the editor tracking the issue goes away. NB I'd like to see editor tracking in collector. (is this a bug?)
For editor tracking fields, you need to make sure editor tracking fields should NOT have editable:true
