OD Matrix does not have to be symmetric. A road network may have many one-way streets, turn restrictions or penalties and the fact that it is a directed network, so travel to and travel from impedances may be different for the same edge. All of these can cause the travel time from location 1 to location 500 be different. If you want symmetric values, then either create a network without the above mentioned things (i.e., no turn penalties, no one-way information, no restrictions, and same travel-to/from impedances) OR use one half of the matrix and fill the other side to make it symmetric after the fact.Regards,Jay Sandhu
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
