@michael_vetterの投稿によると、昨日(10月9日)00:00 UTC頃からPower Automateのフローがトリガーされなくなりました。これは新しい問題のようなので、新しいスレッドを作成しました。以前のトリガー問題で見られた症状は今回見られません。ArcGIS REST ServicesページではWebhookはまだアクティブ表示で、Notification Statusテーブルは空です。この問題は、「Response 200」回避策を適用した既存のWebhook(「When a record is updated in a feature layer」と「When a record is created in a feature layer」のWebhook)でも、新しく昨日作成したデバッグ用のフローでも発生しています。これらのフローは昨日以降100回以上トリガーされるはずでしたが、全くトリガーされていません。現在、この問題は@michael_vetterと私たちだけが報告しています。動作停止前に503エラーがいくつか発生しました。他のユーザーも503エラーを受けていますが、そのWebhookはまだ動作しています。@AnthonyLatini、何か試せることやデバッグ方法についてご意見ありますか?
This issue has been fixed as of now. Incase your Power Automate flows are not working as expected, please open a ticket with our team in Technical support and we can have a look at your Organization account.
Following. This has also been occurring with us since the ArcGIS Online Hosted Feature Services Performance issues that occurred on October 7, 2024. Trigger has not fired successfully since Oct 7, 03:56 PM Eastern.
Confirmed by us too.... This technology is incredibly unreliable. Ours hasn't fired since 10/7/24....
@AnthonyLatini
@SeanKMcGinnis
We are experiencing the same issue in Power Automate. We found that if we use the ArcGIS connector as a trigger for a Power Automate flow, the Power Automate Flow will not trigger. If we use the ArcGIS connector as an action in a Power Automate flow, the Power Automate flow triggers and the ArcGIS action executes as expected.
@CatHeindel not sure I understand how to use the ArcGIS Connector as an action vs trigger?
Your flow is triggered by an event in AGOL (create a feature, survey submitted, an attribute is update) vs your flow is triggered by, for example, an list is updated in sharepoint and later on in your flow you have an action in AGOL like create a record.
We have the same issue on our hosted feature service webhooks and the Arcgis Power Automate Connector. By far this is one of the most unreliable products we have used. We are reaching out to file tech support tickets today and to our ESRI rep. Hopefully other folks can file tickets too or reach out to ESRI so we can get more visibility.
Good Day All - there has been an issue identified where some Power Automate flows are not being triggered by a feature service webhook. The team is aware of the issue and is working with multiple other product teams. From the troubleshooting that has been done, it is believed to be related to performance issues in ArcGIS Online which has impacted not only Power Automate, but also Make, FME, and ArcGIS for Python.We are working towards a solution and will keep people posted as more information becomes available.
Could this also be affecting the timeliness of a flow trigger? We are using When a record is created in a feature layer and sometimes it takes over 10 minutes to trigger.
Thanks for the fix! Our webhooks have been triggering the Power Automate flows for the last 90 minutes.
@SeanKMcGinnis and @sosero thank you for replying and letting us know there was an issue. I started seeing Power Automate flows triggering again as well.
This will be a long shot, but do with either of you know if there is a way to access a web hook's log on the AGOL side. I do not see option for a log on the REST service page? Both times when the web hooks went down, I was blind in trying to figure out if the issue was on the AGOL side or Power Automate side. Thank you - Cat
@CatHeindel - as of today, I do not think there is a way to review webhook logs.
I use WebHook.site to set up helpers allowing me to log when webhooks are firing for my critical flows. This allows me to understand the source of the issue - is it Power Automate causing the issue or is it something further upstream and the webhook is not firing.
@SeanKMcGinnis Thank you!! I will give your suggestion a try
Hi All, I am having trouble with Webhooks to AGOL. I am getting the webhook error here:
In finding this and other blogs, it seems like it is related. All layers I have tried have tracking enabled, I have tried setting other permissions, and have even gone so far as using only layers out of my admin account. My situation differs from Cat's in that this is my first go at a PA AGC where I am fetching fields. My PA script to email me when a record is created works, but just not the field fetch. Since I have never had it working, I am not 100% confident if I am doing something wrong or if there is a flaw. It appears that it cant read the fields because the JSON isn't being returned properly. Can you guys help?
I am getting the same error
Hi @AJD and @LisaT,
We have seen a few reports of similar behavior with webhooks in Power Automate and the error message:
Power Automate error message: Flow save failed with code 'DynamicOperationRequestClientFailure' and message 'The dynamic operation request to API 'arcgis' operation 'GetFeatureLayerResponseSchemaForWebhook' failed with status code 'NotFound'.
Some individuals have found improvement with their webhooks as of this morning.
If you are still seeing issues, would you be able to confirm if you are the error message above, share the feature service URL with me (can share here or private message me), and if there is a joined view layer with an area of interest defined?
Thank you,
Katie
So what was the fix??
Hi @KathrynWalker I was having trouble with my Enterprise 11.3 connections due to BUG-000169725
I created a new connection and was able to save my flow. Now I'm having similar issues as described above. When a record is created in a feature layer is not working as a trigger.
Hi @LeviCecil,
Do you know if the layer used in the trigger is a map image or feature layer shared as a reference? You may be running into BUG-000169327 for ArcGIS Connectors for Power Automate. If you contact Technical Support, an analyst should be able to confirm.
Thank you,Katie
Hi Kathryn,
It's a hosted feature layer, and I'm almost certain I didn't publish it from reference. But I could be wrong. Is there a better way to publish it? This bug is from July. Any idea when it will be fixed??
That bug is in product plan, meaning it is set to be fixed in the near-term (next release or two). I would confirm the service URL for the item in the organization. Not just from the item's overview page. Does it say 'MapServer' or 'FeatureServer' within the URL?
It is definitely a feature server. How long is near term? We're about to ditch Power Automate altogether and find or build a custom solution. The ArcGIS triggers have never worked the way they are supposed to. We also tried Make, and that was worse.
Apologies for any frustrations. I'd recommend getting in touch with Esri Support to gather more details and troubleshoot the behavior further.
Well it turns out I had two versions of the dataset, one hosted and on not. 😅 I switched to the hosted version and the trigger is working.
