Is there any file of Data reviewer rules to import?
How can we generate the report using DR?
Can you provide some additional details/background on what you are hoping to implement using Data Reviewer?
1. I am using ArcGIS Pro 3.3. we have our schema while getting data from delivery partners need to
1. Check geometry (null etc) projection system etc.
2. Data compare with our schema so can find the missing FC's
3. Major Topological checks (identical, overlap)
4. Able to find number of Dataset FC and count
5. if possible, can check some major attributes populated or not.
we have data reviewer extension as well but not able to use much except topological checks.
in short need to review the data and can send back to partners with error report.
any help will be greatly Appreciated!...
@Naveen_dd wrote:Hi,1. I am using ArcGIS Pro 3.3. we have our schema while getting data from delivery partners need to1. Check geometry (null etc) projection system etc.2. Data compare with our schema so can find the missing FC's 3. Major Topological checks (identical, overlap)4. Able to find number of Dataset FC and count5. if possible, can check some major attributes populated or not.we have data reviewer extension as well but not able to use much except topological checks.in short need to review the data and can send back to partners with error report. any help will be greatly Appreciated!...
Thanks, Jay, for your response.
point 4 is once we received any GDB, is there any tool to find participating Feature class and their count.
6. another important question is How can we, generate a report of the errors.
please share some link or video by which I can be able to apply data reviewer
Hi Jay, pls share some basic steps as I need to run rules like Check Geometry on all feature classes in different Datasets in a file geodatabase. I have Pro3.4 with Data reviewer ext. in my laptop (standalone).
Pls. consider it something Urgent!!
See my feedback here.
Point 4: The Generate Schema Report tool provides a summary count of the objects contained in a geodatabase.
Point 6: Here's a sample script (blog) for generating an accuracy report based on attribute rule error layers.
