Turning the features on and off by symbology. What is the easiest way of doing this in ArcGIS Pro -
Screenshot from QGIS 3.38.3-Grenoble
Sincerely
Not as easy as QGIS but you can do this using the workflow response from MarkLysecky on this ArcGIS Idea page - Toggle visibility for individual Categories on Sym... - Page 4 - Esri Community - I tested it with unique symbology and it does work.
Thanks Robert. In the same post I saw this. Do you know if this will also be implemented in web, AGOL and Portal? My problem is that making multiple copies of the layer does not allow me to take them offline in Field Maps. So, it has to work across all platforms for me to take this layer offline with toggle visibility function 🙂
Cheers
I do not know if this will be implemented in ArcGIS Online/Portal but there is something called Exclusive Visibility that looks promising once it's setup for your web layer in ArcGIS Online/Portal.
