We have several links to our content library in Hub that were pointing to
"https://xyz.hub.arcgis.com/explore?layout=grid&sort=Title%7Ctitle%7Casc"
OR
"https://xyz.hub.arcgis.com/explore?layout=grid&query=search%20query&sort=Title%7Ctitle%7Casc"
But now they all return "Page Not Found" errors...I just found out that they changed some of the url structure? Instead of "explore" it is now "search" and instead of "query" its just "q".
Did things change? Was there a recent update?
Yes, there have been changes in the new Search Experience. I posted a similar question and I am getting the similar results.
https://community.esri.com/t5/arcgis-hub-questions/new-hub-search-experience-did-esri-change-the-way/m-p/1383073#M6100
Based on the issue you're encountering with the "Page Not Found" errors and the URL structure changes, it sounds like there might be a need to ensure your items are correctly shared and accessible in your Hub's content library. Here's a workflow that could help resolve the issue:
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
