I can't set up my network data set through the properties, because there is no option or button "ok" in the window.
Is there anyone who know what should I do?
The button appears to be below the edge of the screen. Unfortunately, this dialog can't be resized. Can you adjust your Windows screen resolution or scaling?
You can try using the keyboard shortcut keys. Try Alt and O for the Ok button.
So press both keys together, Alt O
Jay Sandhu
Thanks a lot for your help, it works.
