ArcGIS Pro 3.0.2: Based on which field of the attribute table of the polygon layer of the “service area” in the network dataset the map is symbolized by default?
I couldn’t figure out based on which field of the attribute table of the polygon of the “service area” in the network dataset the map is symbolized.
As per the screenshot below, I observed that the name of the field based on which the symbology is performed is “cutoff”. However, this field is not available in the attribute table of the polygon layer of the “service area” in the network dataset.
Additionally, if the symbology is performed based on any other field of the attribute table of the polygon, the result will not match the presentation of the “cutoff” field!
What could be the issue here? Is this a bug?
