How can I get "cumsum" of an array in CGA? Iterate and build a new array recursively in some way?
Hi @MagnusLundevall,
Yes exactly, here is an example:
cumsum(array) = cumsum(array, 1) cumsum(array, i) = case size(array) <= i: array else: cumsum(setElems(array, i, array[i]+array[i-1]), i+1) Init --> print(cumsum([2,5,1,3.5,8]))
May I ask about the usecase? If it is something common we might add it as builtin function in the future, so you don't have to rely on recursion for this.
Cheers,Jonas
I see. Thanks for the informations.
For min/max of an array there is currently no dedicated function, but you can use sortIndices(), there is an example for this case in the cga reference: https://doc.arcgis.com/en/cityengine/latest/cga/cga-sort-indices-function.htm
Thanks! I have used it in trying to solve Split face into rectangular pieces - Esri CommunityI extract scope.sx for each face edge in an array and want to process it to compute split x's. I also had the need for min(array) and max(array) that return the smallest and largest element, respectively. I did write them in the same recursive manner. It would be great to have these in CGA.
