I am trying to develop an attribute rule to delete the containment association between a point feature and a line feature when the point does not intersect with the line, but I have reviewed the page - Attribute rule dictionary keywords and haven't found this capacity of Arcade. Does it have another way to do it by arcade?
Regards.
You can delete associations like you would delete other features.
return { 'edit': [{ 'className': '^UN_Association', 'deletes': [{ 'objectID': 22 }] }] }
Dear Paul,
Thanks for your reply, may I know which object id, I need to put in the "objectID", is it the container object id or the content object ID?
As I have tried to put those, both get an error "A requested row object could not be located", seems that it cannot find any record in the ^UN_Association.
Regards,
Evan
Neither; it is the objectID of the row in the association table.
If you have the container or the content feature, you can query the association table with https://developers.arcgis.com/arcade/function-reference/data_functions/#featuresetbyassociation
in a Utility Network that is deployed on a Oracle database de name on field of object id is OID but in the documentation apear as objectId
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
