@LindaBeale、@ArthurHaddad、@AnthonyLatini、 @Anonymous User。Power Automateの製品スペースが見つからなかったため、この質問をコミュニティサイトのどこに投稿すべきか分からず、Power Biの下に置いています(すみません!)。先週のESRI UCで、ArcGIS and Microsoft 365: Better Together セミナーでArcGIS for Power Automateがリリースされると発表されました。これはいつ実施され、具体的にどのように接続するのでしょうか?ArcGISは「connector」の下に表示されますか?明確にするために、私たちはgov(政府サブスクリプション)を持っています。それ以外のサブスクリプションの詳細はあまり分かりません。この新しい製品に非常に期待しています!!
We submitted to get to General Availability and are working through some additional requirements to get there. We were hoping to be in GCC by now, and we are actively working to make this happen. Realistically I don't see this landing until March, but the bonus is that we may have a new trigger and more actions by then.
That said... you can have your Power Platform Admin create a new Environment that points to the Preview Region, where you will see the ArcGIS connectors.
https://docs.microsoft.com/en-us/power-platform/admin/create-environment#create-an-environment-in-the-power-platform-admin-center
Hello @COSPNWGuy !
We will be releasing the connector's soon and they will take some time to propagate to the gov tenants. Optimistically thinking it will be available in 4 weeks to make it through all the hoops and into your tenant. You will be able to search for it as a connection and will see the familiar ArcGIS for Power BI logo.
I'll post back to this thread as the different hand offs happen and we're excited to see what you'll be able to do with it!
Cheers,
Andrew
Hi @Anonymous User . Could you provide an update? Still not seeing anything.
We are still about 4 weeks out. We have a few backend things to deploy so that it scales properly, then we have Microsoft certification to pass.
Thanks for the update @Anonymous User.
Hey @Anonymous User. Update? Still not seeing anything.
Ohhhh Haaaappppy Daaaaaaay...........Ohhhhh Haaaaaaapppppy Daaay
It's finally here!!!!!!
Glad you got access to it - please do not hesitate to reach out if you have any questions using the triggers or actions.
