I'd like to change the color ramp used in the 'distress' appearance.
Hi! This is not possible at the moment. Would you simply want to flip the color ramp or define entirely new from and to colors?
New colors. I'd like to go from blue to brown.
I too would like to see either an inverse of the current distress color ramp, or a option to choose color ramp start and end colors.
Dear Ismael,
Is it possible at least to invert the color ramp (ie - green for 10 and red for 0)?
Thanks
Dunga
I would also like to reverse the color ramp, to make a visual slider from 0/bad/red to 10/good/green. I am testing version 3.0.014 and this functionality is not available.
Thank you.
+1 on option to flip the color ramp
Hi All
The range question type was introduced in Survey123 version 3.6. It's similar to the distress appearance, but gives you more flexibility. With range questions you can:
The range question type is covered in detail here: Range—Survey123 for ArcGIS | Documentation
Best,
Jim
Eddy Clark Gary Worley Dunga Bazao Hélène Touyéras Simon Jackson
Thanks a lot for the good news, Jim! This looks very flexible, thus very nice !!
Is there a way to flip the color ramp?
