Hello,
I am trying to set up "CommunicationsDataManagementForArcGISEnterpriseV1" but get attached error during application of asset package.
Is this problem known and is there a solution/fix to it?
Thanks and best regards,Jürgen
Hi Paul,
With the help from Esri support (see case #02696389) we figured out that the problem was caused by a corrupted installation of the "pandas 1.1.3" package. Today, in another attempt to upgrade the untools, ArcGIS Pro installed "pandas 1.1.5" sucessfully and after that also "untools 2.6.2". Right now, I am applying the asset package of the Communication Data Management and it seems to be running successfully as well.
Best regards,Jürgen
Hi Jurgen
Was this asset package modified in any way after being downloaded?
Could you post the message section of the GP tool? This will provide us the version of ArcGIS Pro and the version of the untools.
Hi John
No, I didn't modify the asset package at all. Even the entire environment was set up completely anew with PostgreSQL 11 as enterprise database.
Regards,Jürgen
Hi Michael,
This is what the messages section reports:
ArcGIS Pro 2.6.3.24783
untools 2.6.0
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 3
Asset Package schema version: 2.6
The asset package has the following errors (4/4): Item Field OID Value Message Level 0 B_Subnetwork_ConditionBarriers None None Switch: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error 1 B_Subnetwork_ConditionBarriers None None Coax: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error 2 B_Subnetwork_ConditionBarriers None None Copper: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error 3 B_Subnetwork_ConditionBarriers None None Fiber: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error
Failed to execute (AssetPackageToUtilityNetwork).
Did you have the time and opportunity to look into this?
Meanwhile, I made another test with a new download of the Communication Data Management model, the result was the same.
Thank you very much, best regards,Jürgen
I believe you need to update your version of untools
Hi Paul
I have untools 2.6.0 installed. I think there is no newer version of the untools.
Regards, Jürgen
Hi Matt (hope that's correct)
Thanks for sharing your observations. Since it is not only me that is facing this problem I assume that the problem is related to either the asset package or to the tools that are delivered by Esri. Instead of manipulating the asset package on my own (as you suggest) I would expect Esri to investigate the root cause and come up with an official solution or fix.
Anyone from the Esri solutions team: Please let me know what to expect and how to continue. Thank you.
