In the Design Layout tab of the ArcGIS Open Data portal, I can use the wizard to add a widget to the Body Content section, but cannot select the map widget option from the dropdown Content Type. The options available are 'Text', 'Image', 'RSS Feed' and 'Data Listing' (see screenshot below). The workaround is to switch from 'Wizard' to 'Code'. Any suggestions?
