I successfully published map service containing 60K points. It does not contain attachments. Then use it for viewing in 1 device only for 5 minutes.
Suddenly, the server crashed. The CPU hits 98%.
I have a server with 2 physical cores (4 logical), 16 GB RAM and 500 GB HDD running on AWS. It host Arcgis Server and Portal on the same machine
I have a total of 2 feature services running with dedicated instances (8 maximum instances in total) and 6 map services running with shared instances. So, 8 (2+6) services are in use with 8 in total of maximum instances.
Also I have around 10 hosted map services but not in use.
I have also tested by using Shared instances for Feature Service that is heavily used. I only see 7 instances are created (with 128 MB Heap memory) in the statistics page. But, eventually after 5 days, this configuration lead to crash as well.
Questions :
1. By looking at the feature Service that was created using Shared Instance, can I conclude that the maximum number of instances that the system is created is maximum 7 ?
2. Do 10 hosted map services create burden on the system eventhough not being used ?
3. Why ordinary Map Service crashed ? Is it because it doesn't have any serving instance (the number of instances created on the server already maxed out) ?
4. What is possibly down, Arcgis Server or Arcgis Portal ? or both are down ?
Thanks for any clues
