I need to run a trace where i have to set the barriers based on the water device, asset group = network meter, asset type= supply meter and the specific field = bulk, is it possible? how so
If the field is a network attribute you can do this with four condition barriers: network source, asset group, asset type, and the network attribute.
If the field is not a network attribute, you will need to create barrier features. Use the Select By Attribute tool to select the features in that layer, then add the selected features as barriers in the Trace pane.
If you're trying to do this via a script, use the Add Trace Locations tool to create a barrier layer for the features.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
