I recently upgraded to ArcGIS Pro 3.3.0 and am now unable to reinstall untools for Utility Network. Prior to upgrading Pro, I upgraded the .NET for Desktop to 8.0.5 x64 as requested during my first 3.3.0 install attempt.
After a successful upgrade, I cloned my environment and attempted to install untools from the project Package Manager. The install failed on both frozen and flexible solves with the error: "The environment is inconsistent, please check the package plan carefully. The following packages are causing the inconsistency:", along with the list of incompatible packages.
If I attempt to Update or Update All packages in Package Manager, I receive similar errors.
Stackoverflow posted advice to use the Python Command Prompt to enter 'conda update --all', however this eventually returns the same errors as the Package Manager attempts.
I am a relative novice to these set up configurations and am hoping there is something simple I am overlooking? Any advice is appreciated! Am willing to share the full log outputs as well if it would help (:
