I am currently configuring subnetworks in the stormwater model with the resulting subnetwork name attribute not populating in expected devices/lines after running "Update Subnetworks".
Below are the steps I performed.
- Created a valid subnetwork controller(Outlet, Pipe Outlet) and subnetwork using "Modify Controller". A new subnetwork was added to the subnetwork table.
- Updated the Terminal Connection of the line connecting to the Controller as "Inlet Port" using the Terminal connections tool.
- Validated the network using the network topology tool – resulting in no dirty errors
- Ran the Update Subnetworks tool – resulting in a successful result. The subnetwork is not dirty.
- Ran a Subnetwork Trace which was successful through the first orange line(see picture)
I reviewed the tier and all asset groups/types for devices and lines are members. I also updated the "Is connected" attribute to "True" using the "Update is Connected" tool.
Any ideas on why the remainder of my subnetwork is not updating the expected attribution?
