Is there a way to create a standalone table in a file geodatabase where the table is not registered with the geodatabase? For example, using a geoprocessing tool, ArcPy, etc.
Use case - testing:
- Esri Case #03506437 - ArcGIS Pro 3.2: How-to determine if an item is registered with a GDB or not ?
- BUG-000163772: Views in file and mobile geodatabases do not indicate in their Data Source properties if they have been registered with the database
