My question relates to the Utility Network Communication model. How can I implement the "Blown Fiber" workflow with the data model?
Theoretically, I would first create the structural network from microduct casings and microducts, in which the microducts are connected up to the NIU. I would then do a downstream or upstream trace at the microduct level to determine the entire microduct path from the hub terminator to the NIU. I would then virtually blow my optical fiber into this microduct path.
If I understand correctly, it is in general not possible to run a trace on the structure network, this is only possible for domain networks.
Is my understanding of the Utility Network correct or is there a way to map the "Blown Fiber" workflow with the Communication data model?
If anyone has any ideas on this, please let me know.
Thank you and best regards,
Juergen
