I'm trying to get the Address Managment solution deployed on our enterprise rather than AGOL. In the past I've deployed a solution to AGOL and get some test data (Naperville or Atlanta, what ever) but with this deployment I'm presented with options to add fields and domains (to what, I'm not sure; guessing address points and centerlines). I can skip those tasks and then I'm presented with adding data; again, no real specifications although I again assume street centerlines and address points. If I skip that task, I'm basically done. But have nothing.
The address management story map shows what I was expecting to see; projects, data etc. My guess this is through the AGOL deployment. Is that the only way to deploy the solution and get the test data as well as aprx's? My objective is to determine if the solution will work for us.
Chris Fox
