Hello Everyone
A user today gave me a fGDB with a Polygon Feature Class PHK_PY (FC) with around 1000 features to load into our Oracle eGDB. This FC had three Spatial Grid Levels set G1 380 G2 1200 G3 3500.
Current environment:
Geodatabase 10.7.
ArcGIS Pro 2.9.4
Oracle 18.6.0.0
ST_GEOMETRY
Windows
When I used ArcGIS Pro to copy and paste it into the eGDB I got the following error:
Exception: ERROR 000260: Underlying DBMS error [Error executing PL/SQL Block db_stgeom_create_index::ORA-29855:
Fehler bei Ausführung der Routine ODCIINDEXCREATE]--DBMS table not found [ORA-04043: Objekt GEOTEST.PHK_PY ist nicht vorhanden]
[GEOTEST.PHK_PY] ERROR 000260: Underlying DBMS error [Error executing PL/SQL Block db_stgeom_create_index::ORA-29855: Fehler bei Ausführung der Routine ODCIINDEXCREATE]--
[GEOTEST.PHK_PY] Failed to execute (Copy).
I then used the Add Spatial Index Tool and set the Spatial Grid Levels to G1 380 G2 0 G3 0 in the fGDB - this then imported correctly into the eGDB.
So my question is: Are the Spatial Grid Levels G2 and G3 important for eGDB - whereas I read that these are ignored by ArcGIS Pro - I have been working with eGDB/Oracle/SDE since 2005 and I'm a bit confused?
I have a vague memory of this issue but that was way back in 2009 or so....
Feedback welcome and appreciated.
