Hi all - I'm running into an issue when trying to run a subnetwork trace working with storm water data. I have a small subnetwork set up, and the trace runs, but stops when it reaches the first manhole configuration with associations. The trace should continue through the associations to a point where I manually split the line to designate a small area to work with.
General notes about my setup
- I am working with a file gdb utility network, and have successfully set my subnetwork controllers, validated the area, and have updated the subnetwork.
-There are no dirty areas in the extent I am working in
-The subnetwork still shows "isdirty: true" after running the update subnetwork tool since the manage isdirty is set to false.
-Running a connected trace shows that everything in the area is connected properly
-I am working with pro at 2.9.4 and do not wish to upgrade any further
Any help is greatly appreciated!
