This document describes some advanced features of the CityEngine VR Experience. The basic information is available here: https://arcg.is/0u0y11. We recommend to read the basic information first before going into the details provided in this document.
Note: This document refers to CityEngine VR Experience 2021.1, CityEngine 2021.1, and Unreal Engine 4.27. The CityEngine VR Experience is available at the Unreal Marketplace, follow this link to get the template project for free.
Materials
Special Considerations for Materials in the VR Experience
The CityEngine VR Experience requires specially modified materials (VR Materials) for the experience to work properly. This VR materials are automatically created when the level is saved, but they can get outdated if the materials used in the scene are changed after the level was saved for the first time. The outdated VR Materials can be updated using the following two steps:
- Click the Create VR Materials button in the CityEngine Toolbox
- Click Save All to make the changes persistent.
Using Adobe / Allegorithmic Substance Materials
This section describes how to use Substance materials in combination with CityEngine Datasmith exports. The following steps highlight the general workflow, which can be repeatedly applied as your CityEngine scene evolves:
- In the Epic Games Launcher, download the Substance Plugin from the Marketplace.
- Create a new CityEngine VR Experience project and enable the plugin.
- In the Material folder of your Unreal project, create a new folder named SubstanceMaterials.
- Open Substance Source and download a material you want to assign from CityEngine.
- Right click on the material (filename ending with _MAT. In our example Royal_Range_Combined_MAT) and press Copy Reference. This will copy the file path for later use in CityEngine.
- Go back to CityEngine, open your scene. Using the model hierarchy view, inspect the facade you want to apply your Substance material to. Double-clicking on the node will move you to the corresponding part of CGA code.
- Insert the command at an appropriate location in your Rule file:
set(material.shader, "<material_path>")
- Replace <material_path> with the path to the material previously copied in Unreal Engine. In our example, the path was "Material'/Game/Materials/SubstanceMaterials.Royal_Range_Combined_MAT.Royal_Range_Combined_MAT".
- Remove the leading Material' and the trailing .Royal_Range_Combined_MAT' and replace <material_path> with this path. The resulting CGA command should look like this:
set(material.shader, "/Game/Materials/SubstanceMaterials/Royal_Range_Combined_MAT")
- Export your scene using the Unreal Engine exporter.
- Go back to Unreal Engine and import the exported datasmith file into the previously created CityEngine VR Experience project with the Substance material.
Terrains / Landscapes
Starting with CityEngine 2019.0, exporting terrains is handled natively by the CityEngine Unreal exporter.
Which terrain layer are exported to Unreal can be set in the export dialog:
The scenario export python script automatically exports all visible terrains.
For each terrain layer a terrain actor is created in Unreal. If it should be possible to grab the terrain in the VR Experience with the controller, the Generate Overlap Events property of the terrain must be set to true as shown in the screenshot below:
Depending on the size of the terrain, this can sometimes lead to performance problems. To increase the performance at runtime, increase the Simple Collision Mip Level at the cost of accuracy. In that case, we recommend using values in the range between one and three.
Multiplayer Support (Experimental)
With the experimental Multiplayer feature, multiple people can join the same VR Experience and interact with each other in a local network. First one user has to host a server and then other users can join this server.
Hosting a Server
Hosting a server: press "H" on the computer keyboard to host a server.
Joining a server: press "J" on the computer keyboard to join an existing server in the local network.
Batch-Replacing Actors and Foliage
The Replacement Tool is used to batch-replace placeholder objects exported from CityEngine with high quality assets in Unreal. The following section describes how objects need to be exported in CityEngine and how the Replacement Tool can be used in Unreal.
CityEngine
First a placeholder object needs to be inserted in CityEngine using the CGA insert command as follows (hint: the Scatter Operation can be used to distribute the objects):
primitiveQuad(0.2,0.2)
i("garden_plant.obj")
The garden_plant.obj can be any object (even a simple cube) as it will be replaced in Unreal. Note that each object you want to replace needs a unique name as the name is used in Unreal to discern between the different Actors. In CityEngine's Unreal Export settings, Instancing needs to be set to Use Instancing so that each placeholder is imported as a separate actor in the scene, named after the asset that created them (in this case the ‘garden_plant.obj’).
Unreal Engine
Import the Datasmith file as usual. Once the import completes, the result should look something like the scene in the image below.
The Replacement Tool helps batch-replacing the white cubes. It can be found in Unreal Engine in the CityEngine Toolbox:
After selecting the menu item, a dialog with a number of options opens. The image below shows a sample dialog to replace our placeholders with the HillTree_02 model (from Epic Games' Open World Demo Collection😞
Following a description for all options of the Replacement Tool:
- Type: Select the type of object you want to replace, and the type of object you want it to be replaced with.
- Filter: Select the criterion for finding the objects that will be replaced, usually we use the name of the actor.
- Scale: Select the scale of the new object. You can either chose to keep the original scale of the placeholder, or to scale the new object randomly within the domain that you specify.
- Replacement: The Replacement Mesh selects the path to the new object, i.e. the object to be used instead of the original one. The replacement percentage defines how many of the existing actors that meet the filter criteria will be replaced. You can add as many replacements as you want for the same criteria. This allows you to distribute different plants using a single placeholder by experimenting with different replacement percentages and executing them one after the other until the desired density has been reached.
- Add to List: You can save your previous replacements in the List so that you can easily repeat them by enabling them and clicking on ‘Execute enabled replacements’.
Note that you can undo the replacement in Unreal Engine with a simple Ctrl+Z, so that you can easily adjust your percentages and parameters until you find the right mix of actors. Here’s what our garden looks like after the execution of multiple replacements:
Note: The Replacement Tool is currently in beta.
Non-photorealistic Sketch Rendering
An experimental non-photorealistic (NPR) shader can be enabled/disabled to highlight edges as shown in the screenshot below:
The shader can be enabled/disabled from the CityEngine Toolbox:
Level of Detail
Unreal Engine can automatically generate Level of Detail (LoD) for meshes. This section briefly describes how these LoDs can be generated and how the settings can be tweaked to get optimal results. There are two ways to create and edit your LoD settings: LoD for a single mesh and LoD for multiple meshes.
LoD for a Single Mesh
- Open the asset in your content browser and navigate to the details panel.
- Assign a predefined LoD group to the mesh (for buildings, "LargeProb" is a good choice)
- Choose the amount of LoDs you would like to have and save (4 - 6 usually).
LoD for Multiple Meshes
- If you have multiple meshes (buildings) use the Bulk Edit over Property Matrix.
- Experiment with the LoD settings for a single mesh before starting to the edit multiple meshes with the property matrix.
Note: When editing multiple assets over the Property Matrix, Unreal Engine starts to calculate immediately when you hit enter, which potentially leads to very long computation times.
Recommended LoD Settings for VR
In VR the LoD Screen Size needs to be adapted as the resolution is typically higher then no VR. Adjusted Screen Size percentage settings for a VR-Project could look like this:
- LoD Levels: 4
- Switch to Level 1 from 0 at Screen Percentage 60%
- Switch to Level 2 from 1 at Screen Percentage 40%
- Switch to Level 3 from 2 at Screen Percentage 20%
- Switch to Level 4 from 3 at Screen Percentage 10%
For details further details, please refer to Setting Up Automatic LOD Generation documentation.
Changing the Office Skybox
The skybox (i.e. the surroundings outside the office) can be replaced with a different 360° panorama as follows:
- Import the new image containing the 360° panorama for the skybox either by dragging it from the Explorer into the Content Browser or through the Import button in the Content Browser. Note that the image must use equirectangular projection such as the image below.
- Open the imported image and set the value for "Level of Detail -> Mip Gen Settings" to "NoMipmaps".
- Save the changes and close the tab.
- Navigate to "Content -> Maps -> Room -> Skybox" in the Content Browser and open the "MI_EquirectangularRoomSkyBox" material instance.
- Change the value for "Parameter Groups -> SkyBoxTexture" to the newly imported image.
- Save the changes and press play to test if the Skybox is displayed correctly.
Non VR
It is possible to visualize the data imported from CityEngine in a desktop application without VR. To create a non VR level either create a new Level or use the NonVRTemplate level at Content/NonVR/Maps. To set this new level as default, go to Edit->Project Settings->Maps & Modes and set the Editor Startup Map & Game Default Map to the new level.
Exporting Metadata from CityEngine to Unreal Engine
Starting with CityEngine 2019.0, it is possible to export metadata (for example GIS attributes) using the Unreal Engine exporter. To do so, export CityEngine models with the following export options:
- Mesh Merging set to "Per Initial Shape"
- Metadata set to "All"
- Instancing either set to "Disabled" or to "Use Instancing", but not to "Use Instancing with Hierarchical Instanced Static Mesh" since the HISMC mesh component type does not support metadata at this point.
If you are using the NonVRTemplate level, you can take advantage of the built-in metadata information display functionality: After starting the level with the Play button, you can look around while pressing your right mouse button and move around using the W, A, S and D keys. Left clicking will highlight the selected actor and show its metadata in a popup.
To see the Metadata in the Unreal Engine Editor first select the <ShapeName>_Root Actor (there is one Actor for each exported initial Shape from CityEngine) and then its Root Component. The metadata is visible in the Asset User Data Section in the Details Panel as seen in the screenshot below:
