We have ArcGIS Portal (10.5) set up in a 'Federated' environment. We get nightly updates to a SQL server database with new individuals with latitude and Longitude information. I have been able to create a map using ArcGIS desktop that shows the 'Points' on the map. I have been able to publish the layer as a service to our Portal environment successfully. However, after publishing the map to portal, when the nightly updates to the SQL Server database take place, the values that are visible from the Portal do not appear to be updated.
Can someone share with me the steps of how to create a map that will live in the portal, that will be able to reflect the nightly updates from the SQL server?
Thank you so much for your time!
Respectfully,
Eric Anderson
