I have been trying to load Naperville into a SQL Enterprise Geodatabase via Apply Asset Package, runs to completion except when I choose to Load, then it just finishes quietly before it should (but starts Failed Today at ... why is it always today?;).
Python window was set up prior like ...
untools.logger.setLevel("DEBUG")
arcpy.env.parallelProcessingFactor=1
Debug looks like ...
Running script AssetPackageToUtilityNetwork...
2019-10-17 13:45:19 ArcGIS Pro 2.4.2.19948
2019-10-17 13:45:19 untools 2.4.2
2019-10-17 13:45:19 Executing from ArcGIS Pro, 2 map(s), activeMap = False
2019-10-17 13:45:19 Parallel processing enabled: 3
2019-10-17 13:45:19 ****PARAMETERS****
2019-10-17 13:45:19 {'Asset Package': 'D:\\TempPath\\Electric_AssetPackage.gdb', 'Domain Networks to apply': ['Electric'], 'Input Utility Network': 'C:\\Users\\dataload\\Documents\\ArcGIS\\Projects\\Demo_Naperville\\sde-dev.gis.energyqonline.com.au DEMO_NAPERVILLE as UNOwner (4).sde\\DEMO_NAPERVILLE.UNOWNER.Electric\\DEMO_NAPERVILLE.UNOWNER.UtilityNetwork', 'Load data': True, 'Calculate Spatial Index and Analyze': True, 'Output Utility Network': None, 'Configuration options': [], 'Rename using': None}
2019-10-17 13:45:19 untools.gptools.tools.AssetPackageToUtilityNetwork.run(asset_package='D:\\TempPath\\Electric_AssetPackage.gdb',
utility_network='C:\\Users\\dataload\\Documents\\ArcGIS\\Projects\\Demo_Naperville\\sde-dev.gis.energyqonline.com.au DEMO_NAPERVILLE as UNOwner (4).sde\\DEMO_NAPERVILLE.UNOWNER.Electric\\DEMO_NAPERVILLE.UNOWNER.UtilityNetwork',
networks=['Electric'],
load=True,
calculate_analyze=True,
configurations=[],
rename_field=None)
2019-10-17 13:45:19
Asset Package schema version: 2.4
... and so on until ...
2019-10-17 13:59:56 ...SetSubnetworkDefinition (13/26)
2019-10-17 14:01:21 Start Time: Thursday, October 17, 2019 2:00:19 PM
Succeeded at Thursday, October 17, 2019 2:00:57 PM (Elapsed Time: 38.03 seconds)
2019-10-17 14:01:21 Append (5/13)
2019-10-17 14:01:21 Starting 3 processes for Append
Succeeded at Thursday, October 17, 2019 2:01:24 PM (Elapsed Time: 16 minutes 6 seconds)
There are no doubt some really useful files created like logs, and maybe copies of .py files which I could look at to see what is supposed to happen after "Starting 3 processes for Append", I just don't know where to look for them.
Also if I set arcpy.env.parallelProcessingFactor=1 why at the end of the Debug does it say 'Starting 3 processes' ?
Cheers
Will
