I have some parcel data that has more than 1 space between the Township/Range section and the Lot eg:
1N1E36D -00100
However in both ArcGIS Pro and ArcGIS Online the popup strips the internal spaces to just one space.
1N1E36D -00100
I have tried arcade expressions to get the popup to render the internal spaces correctly to reflect how they are in the database:
Replace($feature.PARCEL_APN," ","nbsp")
but it shows this instead:
1N1E36Dnbspnbsp-00100
* note I used the correct syntax, i just used the incorrect syntax here so it wouldn't render as spaces
The popup always strips them after the expression calculation so it doesn't matter what I do in the expression builder for configuring the popup. This also happens in ArcGIS Online as well.
Am I just missing the sytnax or is this one of those it's a feature not a bug kind of things?
