I am new to ARCGIS. Can someone show me how can I go about adding 2 states New Jersey and Delaware to the existing code? So that it displays along with New York.
Is there also a wild card option to add all the states?
<!DOCTYPE html><BR /><html><BR /> <head><BR /> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><BR /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples <BR /> on iOS devices--><BR /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"><BR /> <title>Class Breaks Renderer</title><BR /><BR /><SPAN> <link rel="stylesheet" href="</SPAN><A class="jive-link-external-small" href="http://js.arcgis.com/3.11/esri/css/esri.css" rel="nofollow noopener noreferrer" target="_blank">http://js.arcgis.com/3.11/esri/css/esri.css</A><SPAN>"></SPAN><BR /> <style><BR /> html, body, #map{<BR /> height: 100%;<BR /> margin: 0;<BR /> padding: 0;<BR /> }<BR /> </style><BR /><SPAN> <script src="</SPAN><A class="jive-link-external-small" href="http://js.arcgis.com/3.11/" rel="nofollow noopener noreferrer" target="_blank">http://js.arcgis.com/3.11/</A><SPAN>"></script></SPAN><BR /> <script><BR /><BR /><SPAN> //</SPAN><A class="jive-link-external-small" href="https://developers.arcgis.com/javascript/jssamples/renderer_class_breaks.html" rel="nofollow noopener noreferrer" target="_blank">https://developers.arcgis.com/javascript/jssamples/renderer_class_breaks.html</A><BR /> var map;<BR /> require([<BR /> "esri/map", "esri/layers/FeatureLayer",<BR /> "esri/InfoTemplate", "esri/symbols/SimpleFillSymbol", <BR /> "esri/renderers/ClassBreaksRenderer",<BR /> "esri/Color", "dojo/dom-style", "dojo/domReady!"<BR /> ], function(<BR /> Map, FeatureLayer,<BR /> InfoTemplate, SimpleFillSymbol, <BR /> ClassBreaksRenderer,<BR /> Color, domStyle<BR /> ) {<BR /> map = new Map("map", {<BR /> basemap: "streets",<BR /> center: [-74.215, 42.382],<BR /> zoom: 7,<BR /> slider: false<BR /> });<BR /><BR /> var symbol = new SimpleFillSymbol();<BR /> symbol.setColor(new Color([150, 150, 150, 0.5]));<BR /><BR /> // Add five breaks to the renderer.<BR /> // If you have ESRI's ArcMap available, this can be a good way to determine break values.<BR /> // You can also copy the RGB values from the color schemes ArcMap applies, or use colors<BR /> // from a site like www.colorbrewer.org<BR /> //<BR /> // alternatively, ArcGIS Server's generate renderer task could be used<BR /> var renderer = new ClassBreaksRenderer(symbol, "POP07_SQMI");<BR /> renderer.addBreak(0, 25, new SimpleFillSymbol().setColor(new Color([56, 168, 0, 0.5])));<BR /> renderer.addBreak(25, 75, new SimpleFillSymbol().setColor(new Color([139, 209, 0, 0.5])));<BR /> renderer.addBreak(75, 175, new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5])));<BR /> renderer.addBreak(175, 400, new SimpleFillSymbol().setColor(new Color([255, 128, 0, 0.5])));<BR /> renderer.addBreak(400, Infinity, new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5])));<BR /><BR /> var infoTemplate = new InfoTemplate("${NAME}", "${*}");<BR /><SPAN> var featureLayer = new FeatureLayer("</SPAN><A class="jive-link-external-small" href="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3" rel="nofollow noopener noreferrer" target="_blank">http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3</A><SPAN>", {</SPAN><BR /> mode: FeatureLayer.MODE_SNAPSHOT,<BR /> outFields: ["*"],<BR /> infoTemplate: infoTemplate<BR /> });<BR /><BR /> featureLayer.setDefinitionExpression("STATE_NAME = 'New York'");<BR /> featureLayer.setRenderer(renderer);<BR /> map.addLayer(featureLayer);<BR /> });<BR /> </script><BR /> </head><BR /><BR /> <body><BR /> <div id="map"></div><BR /> </body><BR /><BR /></html>
