I have two polygon feature classes: Basins, and Nexrad. Nexrad contains a field called 'value' which contains floating point numbers. I am trying to populate a new field with the sum of 'value' for all intersecting nexrad polygons for each basin feature. I am trying to loop through each basin, select all nexrad polygons that intersect the selected basin, calculate the sum of the 'value field in nexrad, and add that sum to a new field in the basins. Right now my script loops through correctly but only adds the sum from the last 'select by location'.
# Import Modules
import arcpy
import os
import numpy
from arcpy import env
# Set environment and workspace
env.workspace = r"W:\Citrix\34000s\34624\001\GIS\RainfallDepthTool\RainfallDepth_NK.gdb"
print ("Environment set!")
# Set ariables
basins = r"W:\Citrix\34000s\34624\001\GIS\RainfallDepthTool\RainfallDepth_NK.gdb\Basins"
nexrad = r"W:\SAN\34000s\34624\001\DataIn\NEXRAD_9_22\shp\hourly\KEWX_N1P_20180922_075800.shp"
# Add a field to the basins to be populated with Nexrad polygon value
arcpy.AddField_management(basins,"NexradValue","FLOAT")
# Create Feature Layers
arcpy.MakeFeatureLayer_management(basins,'basinLyr')
arcpy.MakeFeatureLayer_management(nexrad,'nexradLyr')
print ("Layers created!")
field = 'Shape@'
with arcpy.da.SearchCursor('basinLyr', field) as cursor:
for row in cursor:
# Get geometry to use in select by location
geom = row[0]
# Select nexrad polygon that intersect the selected basin
x = arcpy.SelectLayerByLocation_management('nexradLyr', 'INTERSECT', geom, '', 'NEW_SELECTION')
# Calculate the sum of the 'value' field in the selected nexrad polygons
field = arcpy.da.TableToNumPyArray (x, 'value')
sum = field['value'].sum()
print(sum)
arcpy.CalculateField_management('basins','NexradValue',float(sum))
print ('Field Calculated!')
print ("Done!!!")<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
