Issue:
In Survey123 Connect, the image question is configured with method=camera to require surveyors to capture photos using the device camera. However, when the camera functionality is disabled on the mobile device or camera access is unavailable, Survey123 automatically provides the option to attach/select an existing image from the device.
This behavior may allow surveyors to bypass the intended camera-based photo capture process by attaching an existing photo instead.
Expected Behavior:
When method=camera is configured, the survey should require a photo captured through the device camera. If camera access is disabled or unavailable, the image question should not automatically provide an attachment/browse option that allows the surveyor to select an existing photo.
Actual Behavior:
- method=camera is configured in Survey123 Connect.
- When camera access is available, the camera capture option works as expected.
- When camera access is disabled on the mobile device, an attachment/browse option becomes available.
- This allows the surveyor to attach an existing photo instead of taking a new photo.
Impact:
This may affect photo validation and field data integrity, particularly for workflows where the photo must be captured directly during the survey and should not come from the device's existing gallery.
Request:
Please confirm if this is the expected behavior of method=camera and if there is a configuration or parameter that can completely prevent users from attaching/browsing existing images when camera access is disabled or unavailable.
