Curious if there is a means of using the custom geopoint icons in report maps that aggregate points done in the survey. While the custom icon displays in Connect and Field App, web I know is a missed opportunity, with that said, does this also trickle down to reports as well? Would there be a way to store said custom icon for a repeating field in a calculation for a media field and then use that in lieu of the default pin. OR are the only icons that is applicable to are the doticons that ESRI hosts themselves?
