Is there a way to create an Extent Indicator with rounded corners? The Map Frame whose extent is being indicated has rounded corners* but the Extent Indicator is a rectangle with 90° corners.
I attached a screenshot of my Layout (see Layout.png). The shape in the bottom right corner is my INSET FRAME, and the rectangle in the middle is my Extent Indicator. I have "Frame" selected in the shape section of the Extent Indicator Properties, so it should be reflecting the shape of my INSET FRAME, right? See Extent Indicator Properties.png
Lastly, I attached a layout file (see Extent Indicator with Rounded Corners.pagx) so you can see my exact setup.
*In the INSET FRAME properties, I am limited to 50% for rounded corners. Is there a way to get values above 50% here? See attached image INSET FRAME Properties.png
