Does anyone have a clue as to why a database sequence fires 100% of the time when creating a feature in Field Maps but is somewhat hit or miss or delayed when creating it in from Map Viewer in Portal (version 10.9.1) ?
We are using this as an attribute rule where "M_FID" is used as the sequence name in the database with an insert Trigger:
var id = NextSequenceValue("M_FID")
return "M-" + idI wasn't sure if there was any reason for this or if anyone else has experienced this.
Thanks!
