ArcSDE User-Schema Geodatabases in Oracle are deprecated.
________________________________________________________________________________________________
2. DEPRECATION PLANS
What are the deprecation plans for ArcGIS products?
IMPORTANT: If you are using ArcGIS Pro 3.x and trying to edit data and use geodatabase features like Traditional Versioning and or Branch Versioning with an ArcSDE User-Schema Geodatabase in Oracle, then this is not a recommended nor a supported workflow with ArcGIS Pro.
3. GEODATABASE COMPATIBILITY
4. MIGRATE YOUR DATA
If you are working with ArcGIS Pro 3.x then you need to migrate the ArcSDE User-Schema Geodatabase in Oracle to an
